Authorize with your Portal
In order to create content or interact with non-public items in ArcGIS Online or ArcGIS Enterprise, you will need to be authorized using one of the following methods:
Items in ArcGIS Online and ArcGIS Enterprise can be unshared (accessible only to the item owner) or shared to groups, your organization, or everyone (). Learn more about Sharing here. Read and write access to an item is controlled by the owner-specified sharing level, organizational security settings, and the accessing user’s privileges.
Authorization with OAuth2
There are two ways to authorize with OAuth2: either by using a a code
or a client
flow. Code-based authorization is interactive, requiring you to copy an authorization code from a browser window into the R console during the execution of your code. Client authorization allows for non-interactive scripting, but cannot be used for creating or modifying content. In most cases, code-based authorization is recommended. These two methods are explained below.
Before you can authorize with either OAuth2 method, you must first create a client ID.
Obtaining a Client ID
If a client ID is not provided to you by an administrator and you have the ability to create content items, you can create one.
You can do so by creating an application item.
- Log in to your ArcGIS Online or ArcGIS Enterprise organization
- Navigate to the Content tab
- Click
New Item
- Select
Application
- Choose
Other application
as yourApplication Type
- Give the item an informative name such as
r-arcgis
- Optionally, specify the folder, tags, and summary as well.
- You will be directed to the item details page of the newly created application where you can see your credentials. Do not share these.
Securing your credentials
By default, packages in the {arcgis}
metapackage are configured to work with ArcGIS Online. arcgis
utilizes environment variables to determine how requests are crafted and where requests are made. These environment variables are:
ARCGIS_HOST
ARCGIS_CLIENT
ARCGIS_USER
ARCGIS_SECRET
ARCGIS_TOKEN
ARCGIS_HOST
is used to to determine where authorization takes place. By default, this is"https://www.arcgis.com"
. This is because the packages, by default, interact with ArcGIS Online. To use a different portal, you will need to modify theARCGIS_HOST
path to url of that portal.ARCGIS_USER
variable is used to determine who actions are performed on behalf of. Notably, it is used in functions that modify or create resource such as functions fromarcgislayers
:create_service()
,add_item()
, andpublish_item()
.ARCGIS_CLIENT
andARCGIS_SECRET
environment variables are used only in theauth_client()
OAuth2 client flow authorization. See the article on authorization for more.
Setting your credentials in .Renviron
Environment variables should never be included in your code. Instead, they should be stored in an external environment file such as an .Renviron
file. To modify your .Renviron
, you can use the usethis
package. Ensure it is installed and run the following in your text editor:
If you modify environment variables you will need to restart your R session for the change to be registered.
.Renviron
scopes
.Renviron
files can be created at a user level or a project level. It is recommended to use project level .Renviron
files when deploying scripts to production. If most of your work is interactive then a user level file is sufficient.
Project scoped .Renviron
files store environment variables that are available for the project only. The .Renviron
is stored at the root folder level.
User scoped .Renviron
files store environment variables in the user’s home directory. The environment variables will be available to you in any project you open. However, if you share your project, the environment variables will not be shared with it.
This will open your .Renviron
file for you to edit. Fill in the environment variables ARCGIS_CLIENT
and ARCGIS_SECRET
from the content item you just created. If you are not using ArcGIS Online, ensure that your portal’s host is provided to ARCGIS_HOST
. Additionally, provide your username to ARCGIS_USER
if you plan to use username and password authentication.
ARCGIS_CLIENT=your-client-id
ARCGIS_SECRET=your-super-secret-key
ARCGIS_HOST=https://your-portal.com/
ARCGIS_USER=your-user-name
Do not put environment variable values in quotation marks.
If you are using ArcGIS Online, you do not need to set the environment variable ARCGIS_HOST
Be sure to save your changes to the file. To register the new environment variables, restart your R session.
Authorizing
First, load the library.
library(arcgis)
#> Attaching core arcgis packages:
#> - {arcgisutils} v0.1.0
#> - {arcgislayers} v0.1.0
Code flow
The OAuth2 Code Flow is a process where a user authorizes an application to act on their behalf by granting a temporary access token. This type of authorization permits the application to take actions on the user’s behalf for the duration of the access token. Learn more about how ArcGIS uses OAuth2.0.
Running auth_code()
will open a tab in your browser to begin the code flow. If you are authorizing to an ArcGIS Enterprise portal, ensure that you set the ARCGIS_HOST
environment variable correctly and that you have restarted your R session.
You will be prompted to sign in to your portal.
Once you’ve signed in, copy the code that appears, and return to R. Enter the code into the console without any modifications and press enter.
Your authorization will have completed.
token
#> <httr2_token>
#> token_type: bearer
#> access_token: <REDACTED>
#> expires_at: 2023-03-03 13:21:40
#> refresh_token: <REDACTED>
#> username: your-user
#> ssl: TRUE
#> refresh_token_expires_in: 1209599
Authorization tokens are temporary and will expire. If you encounter an invalid token error, you might need to generate a new token.
To make this token easily accessible to {arcgis}
, use set_arc_token()
which sets the token in dedicated authorization token environment.
Client flow
Alternatively, you can authorize using the client OAuth2 flow. This will authorize the application you created and not ourselves. Because of this, you cannot use the client flow to create or modify content.
The client flow has the benefit of being non-interactive, though.
Authorization with Named User
Authorizing using an ArcGIS Online or ArcGIS Enterprise username and password is a legacy method that is supported for cases where OAuth2 is not implemented. As a reminder, credentials should never be stored in plaintext in code.
Security consideration: Obtaining an access token with this method will expose the username and password credentials as plain text and could present a potential security risk.
Authorization with ArcGIS Pro and {arcgisbinding}
If you are a user of ArcGIS Pro and have arcgisbinding installed, you can use auth_binding()
to utilize the tokens that result from arc.check_portal()
. auth_binding()
has the benefit of being non-interactive and authorizes you as a user. You can use auth_binding()
for non-interactive work that creates or modifies existing content.
This method retrieves the token from the active portal in ArcGIS Pro. Make sure that you are logged into the intended portal and that it is set as active. If you switch which portal is active in ArcGIS Pro, you will need to restart your R session for the new portal to be recognized by auth_binding()
